FieldPoint Family
Values on front panel not updating when using web publishing
We are using the web publishing tool to make a .html page where we can view the front panel of a program running on a cFP 2120.
The problem is that some of the values does not update, despite doing so internally in the software. --> we can't view the updated values, they just remain at zero, the default value.
One of the values we can't see is an array, and if we right click this array on the web page and select reset array (or reinitialize, I'm not sure) the array starts updating.
Highly annoying, as you understand. Does anyone have a workaround for this bug?
(6,222 Views)
Hi Rodnebb,
Please take a look at the following KnowledgeBase: Why Does My Remote Front Panel Indicator or Control Not Update? which may be able to help you.
Please do not hesitate to reply to this post if this does not resolve your issue.
Ching P.
DAQ and Academic Hardware R&D
(6,206 Views)
