FieldPoint Family
how can i use a global variable if one running in windows and the orher runs in the fieldpoint
i'm running a Vi in the Fieldpoint cFP-2120 and i need a value from a variable that it's running in Windows,
Somebody can help me?
(7,369 Views)
What version of LV are you using?
(7,365 Views)
Labview 7.1
(7,362 Views)
There are several ways to communicate with cFP.  I prefer to use TCP for communicating between PC host and cFP target via network.   There are TCP examples that ship with LV and I'm sure you can find numerous references on the ni webpage.
You can also use DataSocket and Logos.
(7,356 Views)
i'm runing a Vi in the cFP in realtime and i need to do a routine in the cFP Vi  if the varaiable that is runing at same time in windows change. i'm conecting with the cFP by network
Do you believe that this can be with TCP ?
(7,344 Views)
Yes, it can be done with TCP/IP.
See this example of communication on the NI web page.  http://zone.ni.com/devzone/cda/epd/p/id/2088
(7,339 Views)
OK.
I WILL TRY WITH TCP.
THANKS A LOT
(7,335 Views)
