FieldPoint Family
Field point
Hi
I have a problem in field point device.
when i run the program i am getting the error,Error message"FieldPoint:  Unable to load the FieldPoint server .dll. Possible cause: The .dll does not support the required interface"
How can i rectify this
Message 1 of 8
(10,743 Views)
Hi Veeru,
   which hardware/software tools do you use? Which version of the FieldPoint drivers?
   Did you upgraded something from a previous working gear?
graziano
Message 2 of 8
(10,739 Views)
Thanks Graziano
The device is cFP-2000,no i didnt upgraded.
The same program works in other computers.
Message 3 of 8
(10,736 Views)
Hi!
   Sincerely, I don't know. I hope someone of NI support can join this discussion.
   Anyway, I'd try to reinstall FieldPoint Software.  The computer you're talking about is your developement PC (I suppose no)? Has it all the drivers? Can you see cFP-2000 from MAX?
graziano
Message 4 of 8
(10,734 Views)
This computer is the development one.
In Max i can see all the field point devices available.
Thanks Graziano
Message 5 of 8
(10,732 Views)
Hi Veeru,
Thanks a very unsual error to get on one machine, do you have the option of re-loading the software on the cFP controller from that machine and are you sure that the software on the machine with the issues for cFP matches that installed on the controller.
All the best,
Message 6 of 8
(10,697 Views)
hi veeru
can u attach screen shots of ur set up and error
regards mazhar
Message 7 of 8
(10,562 Views)
I am having this issue as well. No software changes have been made to the development machine or the machine that this is being deployed to. Any clue as to what might cause this?
Message 8 of 8
(8,098 Views)
