FieldPoint Family
FP-1601 and labview 6.0.2
We have been running since 2001 an application developed using labview 6.0.2 controlling two FP-1600. One FP-1601 failed, so we replaced it with a new FP-1601. problem is I can't find 6.02 compatible Fieldpoint VIs.
any idea?
thanks Francesco
(7,004 Views)
I am confused.  Are you trying to now modify the application you have been running since 2001?  Are you asking where the FieldPoint VIs are located within LabVIEW, or do you no longer have the FieldPoint driver installed on your machine?  If you do have the driver installed, which version do you have?
-Bob
(6,992 Views)
sorry if I wasn't clear.
labview version 6.0.2
measurement and automation explorer 3.1.0.3021
I can configure and read data from my Fieldpoint ethernet  network (one FP 1601 and one FP 1600) using measurement and automation explorer. I assume that the iak configuration file is ok.
in labview using FP open.vi I get the error -34107 Failed to properly terminate. : FP Open.vi
I thought it is a labview version problem having seen on the installer cd of the FP 1601 module no VIs for labview version 6.0.2, the oldest being 6.1
hoping that now it's clearer
thanks
(6,991 Views)
What does it list as the "possible cause" for this error message?
-Bob
(6,979 Views)
