02-01-2006 10:45 AM
02-02-2006 01:25 PM
Ben,
When you install LabVIEW 8 and the device drivers (that include FieldPoint 5),
the support for FieldPoint in LabVIEW 6 is removed. You can only have one
version of the FieldPoint driver installed at a time, and no FieldPoint driver
will install support for LabVIEW 6, 7 and 8. If you install FieldPoint 5
you will have support for LabVIEW 7.0, 7.1 and 8. If you install
FieldPoint 4.1 you get support for LabVIEW 6.1 and 7.0, 7.1. Although
there is a way to get some functionality of FieldPoint 4.1 in LabVIEW 8 by
copying files into your LabVIEW 8 directory it is not supported and discouraged
since it has limited functionality (you will not be able to target your
device).
If you need FieldPoint support in LabVIEW 6.1, you can uninstall FieldPoint 5.0
and reinstall version 4.1.
Jesse O
Application Engineering
02-02-2006 01:42 PM
This appears to be consistant with what I have found.
I will need a new machine to allow me to install LV 8.
Ben
