02-09-2010 09:18 AM
Is there a way to reorder the sheets so that the renumber of parts will work correctly? Several sheets in my design have been moved by dragging the tab for the sheet to the desired location and the part renumber tool uses the original sheet order when renumbering the parts resulting in an incorrect renumber.
KK
Newbie at this point
02-09-2010 10:41 AM
02-10-2010 12:59 AM
02-10-2010 07:21 AM
02-10-2010 07:50 AM
The task of reordering the sheets is a Multisim 11.0 question.
My apologies for not stating that in my original post.
I did get past the issue by generating a new set of sheets for the design and copying the part to the new sheets in the preferred sheet order and then deleting the original sheets. Then the part renumber tool renumbered the parts correctly.
Thanks for the help.
02-10-2010 07:58 AM
02-11-2010 12:03 AM
02-11-2010 07:37 AM
02-11-2010 09:52 PM
I have and i should have taken the
hint...
