12-13-2004 10:13 AM
12-14-2004
10:14 AM
- last edited on
05-20-2025
06:46 PM
by
Content Cleaner
Most likely, this is due to having a version of Labview that is newer than your Vision Builder / Vision Assistant software. There are updates available for both Vision Builder and Vision Assistant. These updates can be found at:
Vision Assistant 7.0.1 if you previously had Vision Assistant 7.0
Vision Builder for AI 2.0.2 if you previously had Vision Builder AI 2.0
After installing one of the above, everything should work as you saw in the online demonstration.
Hope this helps,
Robert
