Feedback on NI Community
interfacing Vision Builder with Labview version 7.1
i can't export my design in Vision Builder version 7.0 to Labview version 7.1 using the Create Labview VI under the Tools tab as taught in the demo on this website. please advise. thanks.
(3,839 Views)
Most likely, this is due to having a version of Labview that is newer than your Vision Builder / Vision Assistant software. There are updates available for both Vision Builder and Vision Assistant. These updates can be found at:
Vision Assistant 7.0.1 if you previously had Vision Assistant 7.0
Vision Builder for AI 2.0.2 if you previously had Vision Builder AI 2.0
After installing one of the above, everything should work as you saw in the online demonstration.
Hope this helps,
Robert
(3,822 Views)
