09-27-2012 11:30 AM - edited 09-27-2012 11:32 AM
I am failing miserably to find any online help pages for LabVIEW functions, they seem to have disappeared completely. 😞
For example, if I search the site for "flatten to string", I get nothing (see image), even after selecting the help section on the left. I have tried many other LabVIEW function names ("write to spreadsheet file", "index array", "boolean to (0,1)", and it simply does not work anymore. I never had problems in the past.
This is a problem, because if I point out a function here in the forum, I usually link to the online help for clarity.
What changed? In the past, the correct entry was always near the top of the list.
Solved! Go to Solution.
09-27-2012 11:47 AM - edited 09-27-2012 11:47 AM
09-27-2012 11:52 AM - edited 09-27-2012 12:05 PM
@elset191 wrote:
Use google.
sad but true. 😄 (I am always impressed how good google search is!)
So... what broke the search at ni.com?
10-01-2012 11:24 AM
It seems the situation is back to normal. Thanks!
03-11-2013 02:29 PM - edited 03-11-2013 02:29 PM
While the search now works, the results are still slightly out of order, for example the LabVIEW 2011 help page is currently always on top, with the 2012 page second.
I would prefer if they were always sorted, newest first.
Here's a typical result. The first two entries should be swapped.
