Feedback on NI Community
Organizing your images
@Laura F. wrote:
Image albums are turned on. You can go into your image gallery to try them out.
Thanks!
Laura
I see the new format but have no idea how to create folders and mov ethe images.
Could please post a short tutorial?
Ben
Message 11 of 16
(3,549 Views)
There are some good features here!
Below is a screenshot of new actions you get when you hover over images (outlined in red)
The second image, when I click on the light-bulb, links to the Idea Exchange post that the image is embedded in. Likewise, images with a blue folder link to a Board Topic.
I'm guessing that images like the first that have no links can be safely deleted? (since these typically represent "first draft" images replaced by a better image, like above)
Also, I have not tried this yet, but I wonder if a single image embedded in a PM, an Idea, and a Topic will all have icons?
Overall, it's a step up from the previous Image Gallery.
Message 12 of 16
(3,538 Views)
Two minor problems:
  1. Get rid of the bookmark doohickey - it's a performance killer and a nuisance
  2. Pages 13 and 14 (only these two out of 15 pages) return "Message not found" when viewing my public image gallery
Other than that, this is a good upgrade.
Message 13 of 16
(3,533 Views)
Altenbach - I've reported the bug with the cutoff names.
Jack - I've requested the removal of the bookmark button.  Pages 13 & 14 of your images seems to work for me. If you logout of the forums, do you still have the same problem?
Ben - when you upload a new image in your Album page, you can select to create a new album if you wish. Once you've got more than one album, you can move images between the albums.  You'll see an option under Image Options to "Turn on Batch Processing".  Once that's on, you can select images and then use the option "Move Image" under the Image options menu.  You can also delete images easily using the gray "X" that shows up when hovering over the images.  Jack brings up a good point though - you probably don't want to delete images that have been used in a post.  The images used in a post will show another icon indicating if it was a forum message or an idea like in Jack's screenshot.  If there is no icon, it's safe to assume that the image hasn't been used.
Jack - I ran a test that shows even if you manually copy and paste the image URL for and embedded image, the gallery page still provides a link to the thread.
Thanks everyone!
Laura
Message 14 of 16
(3,502 Views)
The bookmark button has been removed from the image pages.
Laura
Message 15 of 16
(3,458 Views)
The cut off rank icon on the image pages is now fixed.
Message 16 of 16
(3,422 Views)
