Feedback on NI Community
New profile for each PC?
Laura,
Each time I use another PC to access the forum, I seem to get a new profile.
At the moment, I seem to have at least 4 profiles, all with the same name. This is next to a few others from old jobs. I did try to change them, but somehow these also got converted to new profiles as well.
In the KUDO list, I am (at the moment) at possition 59, 262, 284 and 1482, all with the same user name (Wiebe@CARYA).
So here are my questions:
Can these profiles be joint? I can come up with the user names and passwords, but all email addresses should be the same as well. These should be two or three different email addresses at most.
How can I avoid this? I am about to switch computer again, and I intent to use the web interface (am using outlook now). But there is no way to choose between the 4 profiles with the same name. I don't want to start over again with my credentials.
Wiebe.
Message 1 of 11
(8,763 Views)
The profiles here are linked to the NI profile. (http://www.ni.com/myni/).
Over the years, I have used many new computers and always got the same profile, so I wonder what's different in your case.  Are you sometimes posting via newsgroups?
Message 2 of 11
(8,751 Views)
Altenbach,
Thanks for the reply. No, I don't use newsgroups, but I do use outlook. I don't think I get a new profile every time I log on to another PC, but somehow I got at least 4 profiles.
I think that, even if you'd try, it wouldn't be possible to create the 4 profiles I have. All the names are the same, and I don't think that is allowed.
I'll be out for this year. Happy Christmas and new year!
Wiebe.
Message Edited by wiebe@CARYA on 12-23-2008 11:27 AM
Message 3 of 11
(8,748 Views)
Hi Wiebe,
When you post using Outlook, you are actually posting through the newsgroup interface rather than this web interface and it gets attributed to this user: http://forums.ni.com/ni/profile?user.id=37618
When you log into the web interface and post, your posts get attributed to this user: http://forums.ni.com/ni/profile?user.id=4177
You have two older user accounts that only posted through the newsgroups.  These two accounts list different email addresses and the current account you use to post via Outlook doesn't list an email address.  Because the newsgroup interface does not authenticate user names it has allowed you to create duplicates.
I don't know of a way to merge accounts.  I'm going to look around and think about this to see if there is something we can do.  By my count, you are almost to the 2,000 post mark!
Thanks and Happy Holidays!
Laura
Message Edited by Laura F. on 12-23-2008 03:24 PM
Message 4 of 11
(8,741 Views)
Hi Wiebe,
I guess this is mainly you because you have logged in with
a different account on each PC and have not logged out
from them. One thing I have observed is that once you login
into forums , it keeps you logged in for a while until you force
log out.
Advice you to go to NI forums on each PC and force logouts
from all of them. Let me know if this problem persistes even after that.
Sundar.
Message 5 of 11
(8,705 Views)
Sundar,
I'm pretty sure this is not what happened. At least not hundreds of times!
Wiebe.
Message 6 of 11
(8,543 Views)
Laura,
Your explaination about why outlook creates another account is plausible. I seem to have 4 accounts though:
http://forums.ni.com/ni/profile?user.id=29566
http://forums.ni.com/ni/profile?user.id=25938
All as Wiebe@CARYA, some with different capitals.
And http://forums.ni.com/ni/profile?user.id=15065 as AIR, indeed with a different email address, although I created my first carya account by modifying this one. Or perhaps another AIR account, and that did succeed. I remember I used to have 2 AIR accounts as well. Oh well...
Wiebe.
Message 7 of 11
(8,542 Views)
Hi Wiebe,
I apologize, I have not looked into this yet for you!  I can give you a quick run down of your accounts though:
http://forums.ni.com/ni/profile?user.id=4177  this is the account you've used to post here and is used any time you log into the web interface of the forums.
http://forums.ni.com/ni/profile?user.id=37618 - this is an account that is used to post from the newsgroups (Outlook) from December 2004 until present.  An email does not show up for this account.
http://forums.ni.com/ni/profile?user.id=29566 - this is also an account from the newsgroups, but it stopped being used when we upgraded the forums in November 2004. It uses a different email.
http://forums.ni.com/ni/profile?user.id=25938 - this account was from 2003.  It uses the email you are using now.
http://forums.ni.com/ni/profile?user.id=15065 - this also uses a different email and came from the newsgroups.
I'm still going to check on the merging accounts issue.
Laura
Message 8 of 11
(8,533 Views)
Laura, are you still watching this thread?
Message 9 of 11
(7,229 Views)
It is jordan now
Message 10 of 11
(7,225 Views)
