10-02-2005 02:04 AM
@Ben wrote:
2) A common location where we could post images before answering questions. This way the pre-posted attachments' upload times do not count against our edit times. All of the images here would automatically link to #1 above.
Why not just start a thread for this yourself?
One potential disadvantage this will have is an address change in the future. The current system will at least (I presume) keep the image with the post.
Another potential problem is that people will use big images, which make reading the page very annoying. In such cases, I usually prefer to open the image in a new window or even download it and open it in a picture viewer.
10-03-2005 04:54 AM
It's even worse. I have, reluctantly, become used to using the advanced search for the forums (which now at least seems to retrieve those posts it didn't use to), but now I tried using the "regular" search box which can be found inside in the thread's page and discovered, to my horror, that it defaults to 90 days (and you only get the option to change it after you do the search). This means that even if there are "regular" users who do decide to search for an answer before posting, they will only be able to get posts from the last 3 months. Why? What's the logic behind this?
@Ben wrote:
1) This line of thought assumes all post worth searching have been posted in the last 6 months.
10-16-2005 03:32 AM
Molly, here's another one to chalk up for the threading issues -
I switched to viewing threads by oldest to newest sorting, which makes the linking OK. This theoretically works fine, but I found out that if you click the number in the New column in the board (which brings you to the oldest unread post in the thread) and then click a link inside the thread (let's say to a picture attachment) and click "Back", you are brought to the first page of the thread and not to the page where you were before. I saw it in several threads, most recently in the Prime number challenge thread, which has a picture in the last page.
10-19-2005 11:25 AM
10-19-2005 12:56 PM
10-19-2005 03:49 PM
Ben & Friends,
You now can add three files to your posts (without having to go back and edit it over and over again).
Have a great day!
10-20-2005 02:20 AM
10-27-2005 05:21 PM
"...I'm guessing many people will go back and edit ..."
Yes.
In my case I took your suggestion and started posting the image before I start the reply. This lets me format my text to better fit the images.
I also finally figured out that I should keep my images small so they do not screw-up up the formatting of the thread. ( I know you did not aim that comment at me directly, but I did finally figure out I was causing problems with "image abuse"). ![]()
Ben
PS
Molly,
Do images count as "1000 words"? It still seems that 5000 character limit is kinda small.
11-13-2005 04:39 AM - edited 11-13-2005 04:39 AM
In the spirit of the discussion here: http://forums.ni.com/ni/board/message?board.id=170&message.id=151310":
It would be nice to have LabVIEW log un-trapped/un-routed errors to an errors-log text file. When having auto-error-handling enabled, one runs the risk of damaging equipment (or worse) when critical-code simply stops for an unanticipated error. When auto-handling is off, we loose possibly valuable diagnostic information. [Optionally] piping those errors to a log would be nice.
Message Edited by Dynamik on 11-13-2005 04:42 AM
11-14-2005 01:19 AM
