Feedback on NI Community
How to undo a community rating
I am more or less familiar with the NI forums where I can kudo (and also unkudo) a message. Unfortunately this undo action this seems not possible with the NI Community.
I have inadvertently rated a document but have not found a way to undo this action. Is this not possibly? Why not?
Also, I can rate the identical document several times, which is also very different from the forum. Is this by design? I find it a bit confusing.
(6,503 Views)
Accepted by Wolfgang
Hi Wolfgang,
The ability to rate a document multiple times is by design. This is meant to give users the option to change their rating of a document - when you do this you are adjusting your preexisting rating, not adding a new one. Unfortunately, there is not a capability to "unrate" a document and remove your rating entirely. I did some digging into this and it appears to be a limitation with our software platform.
However, if you "like" a post unintentionally, clicking the button again will "unlike" it.
I'm sorry about the limited functionality in this case, but you should be able to at least adjust your rating to what you feel is the proper value.
Matt
NI Community Team
(6,480 Views)
Thank you!
(6,474 Views)
