Feedback on NI Community
How to rotate cursor in graph by 90 deg
I am a newbie for Labview. I am using Labview 8.2. I want to detect the peaks ( in realtime )in XY graph, mark them dynamically with cursors  ( each cursor will display the "y - axis" value as well as a particular name ( to be picked up from database or external file , depending on the X-axis value ...X axis is time). Also, I want to rotate these cursors by 90 deg.
Hope , I am clear with my querry.
Nilesh
(6,592 Views)
This is a LabVIEW problem, so you should post this over in the LabVIEW forum. (This place here is for feedback on the forum itself).
What you want seems easily possible, but I don't understand what you mean by rotating a cursor by 90 degrees. That does not make a lot of sense.
(6,589 Views)
sorry for the posting in wrong location. Well I want to rotate the cursor, as I have to display a string (  having about 25 characters in it) in each cursor and displaying them horizontally would be very confusing.....
(6,585 Views)
