Feedback on NI Community
Autoscroll up when placing insert point (android)
Continued from This old problem ...
As soon as a post contains more than the few lines that fit in the edit window, editing gets tedious. (This is often the case when quoting previous posts!) Whenever I place the insert point, the edit window immediately scrolls to the top, moving the placed insert point out of view. To continue editing, I need to scroll the insert point back in view. Sisyphean!!!
Message 1 of 13
(6,168 Views)
Hi Christian,
Is this the same exact issue as what you previously reported in 2017? Is it safe to say that it was mostly resolved as of your last post in the linked topic but it has recently resurfaced?
Did you notice this very recently? We had an update on Thursday morning.
Also, are you still on the same device as last time?
Sorry to hear you're having these difficulties again.
Thanks for the information!
Lili
Message 2 of 13
(6,156 Views)
Yes, I thought it was resolved, but started happening again recently. (Same device, but updated from Android 7 to 8.1 quite a while ago.)
Can anyone else reproduce this?
Message 3 of 13
(6,154 Views)
I saw it on my phone this morning as well.  Not sure what version of Android it is currently running.
GCentral
Message 4 of 13
(6,139 Views)
Hi altenbach and crossrulz,
Thank you both for confirming. We are investigating the issue and will keep you updated with any new information.
Best Regards,
Kristi Martinez
NI Community Support
Message 5 of 13
(6,033 Views)
I wanted to give you an update on this issue. We have confirmed this issue will be resolved in an upcoming release. I will let you know when the fix is live.
Best Regards,
Kristi Martinez
Message 6 of 13
(5,814 Views)
I wanted to let you guys know that the fix for this issue is now live.
Best Regards,
Paula Cerda
Best Regards,
Paula Cerda
Message 7 of 13
(5,708 Views)
Thanks for the update. I'll test it out next time I post by phone... 😉
Message 8 of 13
(5,688 Views)
I still see the same problem. Not fixed for me.
Message 9 of 13
(5,670 Views)
Hi altenbach,
Thanks for checking this. I had tested it with a version 9 and I wasn't able to reproduce the issue.Today I tried with an older version (6.0.1) and the issue remains. On version 9, I noticed that it still happens when the quoted post in the reply has an image on it.
I escalated the issue again and we will keep you updated.
Best Regards,
Paula Cerda
Community Support
Best Regards,
Paula Cerda
Message 10 of 13
(5,649 Views)
