FIRST Robotics Competition Discussions
installation
Can we reinstall the vision example vi only?
Message 1 of 9
(8,357 Views)
Which vision example?
It might be quicker for someone to post it for you
Champion CLA
Making senseless computers do
intelligent real world things
is NOT easy. SO MAKE IT FUN!
Message 2 of 9
(8,352 Views)
The vision vi has been deleted out of our project, when we go to the vision vi example it won't let us open it. I believe the mistake was made by modifying the example and overwriting it.
Message 3 of 9
(8,350 Views)
Should there be a Vision vi at the bottom of this?
Message 4 of 9
(8,333 Views)
Accepted by topic author andivwh
Here are my recommendations.
Look in your project for the  Vision Processing.vi
If you can't find it then I would create a new roboRIO project and copy it over to the current project
Champion CLA
Message 5 of 9
(8,329 Views)
Looking closer at the image you posted it looks like your main while loop has been deleted. The robot main without any modifications should look like this
It also looks like your auto and test reference vis are broken. All these will have to be fixed before you can think about getting the vision to work.
Champion CLA
Message 6 of 9
(8,327 Views)
I am not sure why the screenshot does not show those loops, but they are there. Our robot main looks exactly as your images except, we have now dragged the Vision VI block into the robot main and wired it the same as the camera and timed tasks blocks. We still do not have what we want, but we are not giving up.
Message 7 of 9
(8,319 Views)
Yes it is all still there. We opened the vision processing vi and drug the block  and placed the copy in the robot main.
Message 8 of 9
(8,318 Views)
When we put the program on the robot with the Vision VI block wired in the robot main, this was the result:
  1. we had one camera view and not the other
  2. we switched the camera usb slots
  3. then we could not get anything
  4. we switched back and still had nothing
    However, we have a list of errors if that helps:
    1074360311
    1074360310
    1074360316
    1074360319
Message 9 of 9
(8,317 Views)
