FIRST Robotics Competition Discussions
USB camera only streams to dashboard when temporarily running code from laptop
When we build code and deploy it to the RoboRIO, the camera does not stream an image to the Dashboard. We are using the default dashboard.
However, when I connect a laptop to the RoboRIO and temporarily deploy code by running 'Robot Main' the camera streams images to the Dashboard.
Any ideas on what we did wrong?
(3,352 Views)
Check the "Enable Vision" Boolean on the front panel of "Robot Main.vi"
Omar
(3,342 Views)
That did not work. Same issue even if I clicked the boolean for enable vision and 'save current value as default' prior to building
(3,317 Views)
