FIRST Robotics Competition Discussions
cancelar
Mostrando resultados para
Pesquisar então
Você quer dizer:
Issue with 9403 Module
Hi, I am a mentor and lead programmer from a veteran team of 10 years. We have the old cRIO-FRC that was given a few years ago. My issue started with deploying code to the cRIO with the new LV and image. I first reimaged the cRIO with the latest 2012 image once that was done I noticed that module 9403 was not being detected in slot 2. I know in past years the 9403 module was also put into slot 4 or 6 so I tried both and rescaned for the cRIO in the imaging tool. Even when I did this it still didnt show that the module was plugged in. Needless to say I tried doing this for every slot and still had no luck. The thing is that the module for slot 1 is detected and I tried plugging in 2 different 9403 modules from previous years and neither were being detected. Is there something im doing wrong or are we not able to use the 2012 LV for old cRIO's? Can someone please help me with this?
Mensagem 1 de 2
4.218Exibições
You should be able to use the original FRC cRIO with LabVIEW for this year. The proper slots for the modules are listed in this document:https://decibel.ni.com/content/docs/DOC-20204.  That being said it sounds like you have already tried to use it in this slot. I would start by formatting your cRIO (put it into safe mode and run the imaging tool) and then seeing if you can detect the module after reformatting and reimaging.
Kevin Fort
Principal Software Engineer
NI
Mensagem 2 de 2
3.040Exibições
