FIRST Robotics Competition Discussions
FRC folder
Concerning the FRC forlder for examples, i'm unable to download  or access the folder for 64 bit Labview 2020. As i'm planning on using the example 'simple digital input' as a basis for programming a limit switch for a stepper motor system. This is based of referencing 'Programing a limit switch?' in NI forums.
(3,845 Views)
Hello GeneralStallion,
Please use the downloads that are marked for use in FRC when installing NI software for FIRST Competitions. You can find them here: ni.com/frc
Once installed, you can find the examples in the Help menu > Find Examples..
More information: FRC Tabs Missing on LabVIEW Start Screen
Regarding your question: the FRC software does not execute in LabVIEW 64-bit (hence why the FRC software downloads always install the 32-bit version), because of the LabVIEW Real-Time module used to deploy to the roboRIO.
(3,763 Views)
