SPI Example for the NI PXIe-5644R »
This example implements serial peripheral interface (SPI) communication through the DIO port on the NI PXIe-5644R, including support for both master and slave functionality. |
Description: Serial Peripheral Interface (SPI) buses are commonly used to communicate between a controller (master) device and a target (slave) device. In general, SPI buses require four lines for communication: chip select/clock enable, serial clock, master serial data out (MOSI), and master serial data in (MISO). In some cases only a subset of these lines are used; some devices multiplex both MOSI and MISO onto a single bidirectional data line. This example includes LabVIEW FPGA code for both an SPI master and an SPI slave.
Additional Documentation:
Compatibility:
Dependencies:
FPGA Footprint:
Xilinx Virtex-6 LX195T
Latest Version:
Previous Versions:
Note: All source on this community is distributed using VI Package Manager (VIPM). For more details on VIPM, please read A Note on VI Package Manager
Will this example be available for LabVIEW 2015 anythime soon ? I could not install this version on my system...
