Example Programs
Programmatically Move Any Window to the Front
Overview
This VI will programmatically move a window to the front whether its a LabVIEW window or not.
Description
This VI will programmatically move a window to the front whether its a LabVIEW window or not.  There are two Windows APIs that are used to achieve this.  The first one (FindWindow) acquires the handle of the window that you want to bring to the front.The name of the window is passed into the lpWindowName terminal and NULL is passed into the lpClassName terminal.  The second windows API is SetForegroundWindow. This moves the window corresponding to the passed handle to the front.
Requirements
LabVIEW 2012 (or compatible)
1. Open the VI "Bring Window Forward_LV2012_NI Verified"
2. Choose the window name you want to bring to front
3. Run the VI
4. Stop Execution
Sara Lewandroski
Applications Engineer | National Instruments
http://www.ni.com/support
Comments
Member michelesc
Member
this approach seems not to work if my VI execute a SysExec and wants to keep the external application to the background.
Root cause seems you cannot move a window from a background application (that is, after LV executes Sysexec).
Member Tesla1977
Member
This does not work in Win10. When calling the function when another application is at the front the LabVIEW window simply starts flashing in the taskbar. Any tips?
