Example Code
Programmatically Move Any Window to the Front
Code and Documents
Overview
This VI will programmatically move a window to the front whether its a LabVIEW window or not.
Description
This VI will programmatically move a window to the front whether its a LabVIEW window or not.  There are two Windows APIs that are used to achieve this.  The first one (FindWindow) acquires the handle of the window that you want to bring to the front.The name of the window is passed into the lpWindowName terminal and NULL is passed into the lpClassName terminal.  The second windows API is SetForegroundWindow. This moves the window corresponding to the passed handle to the front.
Requirements
LabVIEW 2012 (or compatible)
1. Open the VI "Bring Window Forward_LV2012_NI Verified"
2. Choose the window name you want to bring to front
3. Run the VI
4. Stop Execution
Sara Lewandroski
Applications Engineer | National Instruments
Comments
michelesc
on
this approach seems not to work if my VI execute a SysExec and wants to keep the external application to the background.
Root cause seems you cannot move a window from a background application (that is, after LV executes Sysexec).
Tesla1977
on
This does not work in Win10. When calling the function when another application is at the front the LabVIEW window simply starts flashing in the taskbar. Any tips?
mckesea7010
on
This approach doesn't currently work for me when incorporating into an executable. Are there are any other files I need to include in my project for this to work in an executable??
wiebe@CARYA
Knight of NI Knight of NI
Knight of NI
on
Posted a new version here. (images and\or attachments are not allowed here?).
That handle needs to be a pointer sized integer.
