Example Code
Xbox 360 LabVIEW Interface
Code and Documents
Introduction
This project shows the power of LabVIEW and its ability to read the inputs from an Xbox 360 controller
Steps to Complete
  1. Make sure that you have a Windows compatible Xbox360 controller and dongle
  2. Turn the controller on
  3. Run the VI and you will notice that you are able to view the inputs from the controller on the front panel of the VI
Additional Notes
There are no side to side inputs to the analog thumbsticks due to project implementation. You are however able to see these very easily if you move the front panel up to the cluster indicators.
Applications Engineer
Comments
momian
on
Could you save this file in LabView 8.0?
thanks,
Jackster
on
Windows 8.1 with LV2012 does notwork...Is there a solution? Works well with 2010 and XP. The controller is seen as ITE, not Xbox.
Thanks for any help.
kdrlzmlr38
on
didn't work for wired one.
Bin2022
on
I tried many examples, but even both (https://forums.ni.com/t5/Example-Code/Xbox-Control-UI/ta-p/3525774) and (https://forums.ni.com/t5/Example-Code/Xbox-360-LabVIEW-Interface/ta-p/3498186) not work.
I found my joystick worked in an online test (https://gamepad-tester.com), so the problem comes from the Labview driver or app.
Later I tried the following and then the above codes worked, for reasons unknown.
(1) I download the compatible Labview VISA driver (refer to https://www.ni.com/en-us/support/documentation/compatibility/16/ni-visa-and-labview-version-compatib...
(2) I assigned 2 rather than 0 to the device index to the Initialize Joystick VI.
Contributors
