Introduction
This project shows the power of LabVIEW and its ability to read the inputs from an Xbox 360 controller
Steps to Complete
Additional Notes
There are no side to side inputs to the analog thumbsticks due to project implementation. You are however able to see these very easily if you move the front panel up to the cluster indicators.
Could you save this file in LabView 8.0?
thanks,
Windows 8.1 with LV2012 does notwork...Is there a solution? Works well with 2010 and XP. The controller is seen as ITE, not Xbox.
Thanks for any help.
didn't work for wired one.
I tried many examples, but even both (https://forums.ni.com/t5/Example-Code/Xbox-Control-UI/ta-p/3525774) and (https://forums.ni.com/t5/Example-Code/Xbox-360-LabVIEW-Interface/ta-p/3498186) not work.
I found my joystick worked in an online test (https://gamepad-tester.com), so the problem comes from the Labview driver or app.
Later I tried the following and then the above codes worked, for reasons unknown.
(1) I download the compatible Labview VISA driver (refer to https://www.ni.com/en-us/support/documentation/compatibility/16/ni-visa-and-labview-version-compatib...
(2) I assigned 2 rather than 0 to the device index to the Initialize Joystick VI.
