Use DMA FIFOs to send data to and from an FPGA target (bidirectional data transfer)
產品與環境
此區段會反映用來建立範例的產品與作業系統。
若要下載 NI 軟體,包括下方所列的產品,請造訪 ni.com/downloads
    硬體
  • CompactRIO|SingleBoardRIO
    軟體
  • LabVIEW FPGA Module
  • LabVIEW Real-Time Module
    驅動程式
  • NI RIO
程式碼與文件
附件
Description
Overview
This example demonstrates how to use DMA FIFOs to send data to and from an FPGA target (bidirectional data transfer).
Description
This project is configured to work with a PXI-7841R on a Windows computer, but this same code will work on any FPGA target and a Windows or a Real-Time Host. This example generates a user defined waveform and sends it down to the FPGA using a Host to Target scoped FIFO. The FPGA then sends it right back up to the Host VI using a Target to Host scoped FIFO. In a real application you would want to process data in between, or just use one FIFO for input OR output.
For more general info on using DMA FIFO's check out this link: Creating FIFOs in FPGA VIs (FPGA Module)
Requirements
 Software
  • LabVIEW Full Development System 2012 (or compatible)
  • LabVIEW FPGA Module 2012 (or compatible)
  • LabVIEW Real-Time Module 2012 (or compatible), if you use a RealTime Target for the Host VI
 Hardware
  • No hardware is necessary to use this example VI. You can migrate this example to any LabVIEW FPGA Target if you want to use real hardware. You must recompile the FPGA VI if you use hardware.
  1. Download and open the attached ZIP-file
  2. Open the [Host] Main.VI inside the LabVIEW project and follow the instructions on the Front Panel
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text ‘NIVerified’. Read here for more information about the new Example Guidelines and Community Platform.**
NI 社群中,來自 Example Code Exchange 的範例程式碼已含 MIT 授權
評論
anonymus
Worked in simulation, but works incorrectly on FPGA
HunterSeeker
How did it behave incorrectly?
anonymus
On FPGA you will see the same number collected in sequence. Like 0,0,0 often at start but at other times as well. It is easier to see if you use a know sequence like 1,2,3,...
davidc10
Do you have an 8.6.1 version?
anonymus
I used 2009 SP1
