Example Code
Use DMA FIFOs to send data to and from an FPGA target (bidirectional data transfer)
Products and Environment
    Hardware
  • CompactRIO|SingleBoardRIO
    Software
  • LabVIEW FPGA Module
  • LabVIEW Real-Time Module
    Driver
  • NI RIO
Code and Documents
Overview
This example demonstrates how to use DMA FIFOs to send data to and from an FPGA target (bidirectional data transfer).
Description
This project is configured to work with a PXI-7841R on a Windows computer, but this same code will work on any FPGA target and a Windows or a Real-Time Host. This example generates a user defined waveform and sends it down to the FPGA using a Host to Target scoped FIFO. The FPGA then sends it right back up to the Host VI using a Target to Host scoped FIFO. In a real application you would want to process data in between, or just use one FIFO for input OR output.
For more general info on using DMA FIFO's check out this link: Creating FIFOs in FPGA VIs (FPGA Module)
Requirements
 Software
  • LabVIEW Full Development System 2012 (or compatible)
  • LabVIEW FPGA Module 2012 (or compatible)
  • LabVIEW Real-Time Module 2012 (or compatible), if you use a RealTime Target for the Host VI
 Hardware
  • No hardware is necessary to use this example VI. You can migrate this example to any LabVIEW FPGA Target if you want to use real hardware. You must recompile the FPGA VI if you use hardware.
  1. Download and open the attached ZIP-file
  2. Open the [Host] Main.VI inside the LabVIEW project and follow the instructions on the Front Panel
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text ‘NIVerified’. Read here for more information about the new Example Guidelines and Community Platform.**
Comments
anonymus
on
Worked in simulation, but works incorrectly on FPGA
HunterSeeker
on
How did it behave incorrectly?
anonymus
on
On FPGA you will see the same number collected in sequence. Like 0,0,0 often at start but at other times as well. It is easier to see if you use a know sequence like 1,2,3,...
davidc10
on
Do you have an 8.6.1 version?
anonymus
on
I used 2009 SP1
