Example Code
Tic Tac Toe
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example allows you to play Tic-Tac-Toe with a friend or against the computer.
Description
This example VI is a variant on an old game. This includes a low level computer intelligence to play against you or you can play with a friend. This is another fun game that was created with LabVIEW and a little imagination. Enjoy!!
For more information about a TicTacToe LabVIEW code, check out the discussion forum here about the LabVIEW Tic Tac Toe Coding Challenge.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Open and Run Tic Tac Toe Main 2012 NIVerified.vi
  2. Chose Player 1(O) and Player 1(X) by selecting the radio buttons below
  3. Play!
  4. Select the “New Game” button to play again
  5. When finished, select “QUIT"
Block Diagram of Tic Tac Toe Main 2012 NIVerified.vi
Logic to check diagonal lines to determine the computer's next move.(in Tic Diagonal Lines 2012.vi )
Logic to check horizontal and vertical lines to determine the computer's next move.(in Tic Horizontal and Vertical Lines 2012.vi )
Comments
rambo
on
can some one post this code for LabVIEW V6.1 ?? thanks
Ben
Knight of NI Knight of NI
Knight of NI
on
Please see this thread
http://forums.ni.com/ni/board/message?board.id=170&view=by_date_ascending&message.id=181709#M181709
in the NI Forums to find the Tic-Tac_Toe challenge.
Can your code beat "Deep-Toe"?
Ben
NIquist
Trusted Enthusiast
Trusted Enthusiast
on
Looks like it's missing a "tic1d.vi" SubVI.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
G-Money
NI Employee (retired)
on
I was working on it just as you posted. Thanks for the input!!
G-Money
on
I unfortunately don't have LabVIEW 6.1 so I can't save it for a previous version. I added some screenshots so maybe you might be able to figure out what I did. You might want to look into a newer version of LabVIEW because NI doesn't support anything before LabVIEW 7.1. Food for thought. Thanks!!
altenbach
Knight of NI
on
For a full featured 4x4 Tic Tac Toe version, have a look at my entry here. It barely uses any pink or green wires (they are for wimps!), doing everything very efficiently using the bits of integers instead.
https://decibel.ni.com/content/servlet/JiveServlet/downloadImage/102-13914-16-15427/310-182/TicTacToePanel.png
