Example Code
Programmatically Display Folder in Windows Explorer using System Exec in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This vi will display a folder path in windows explorer by using system executive.
Description
This vi will programmatically use System Executive to display a folder in Windows Explorer. It uses the file path selected by user and converts to a string which is passed to system exec.vi with the command "explorer <folder path>"
Requirements
  • LabVIEW 2012 (or compatible)
  1. Download vi
  2. Run vi
  3. Select Folder/File
  4. Watch Windows Explorer open with the correct folder!
VI Snippet
Ashish Naik
Automotive Business Development Manager
National Instruments UK
Comments
hex
on
That won't work, you should replace the "empty string" with "space constant". Cheers.
Ashish_Naik_NIUK
NI Employee (retired)
on
Thanks Hex. Slight mis-hap when cleaning up this vi for the community! - Have updated
Ashish Naik
hex
on
Hehe, no problem. I just got real lucky
Jayavel
on
  1. Ya its working good.Thanks for this code
herbert.niesler@emsolutio
on
Works in Vista.  Thanks very much for your vi.
Herbert Niesler
Mads
Trusted Enthusiast
Trusted Enthusiast
on
Another nice option here is the ability to select a file in the opened folder. This can be achieved by adjusting the command with the select switch:
explorer /select,c:\test\hello.dat' will  for example open an explorer window showing c:\test, with the hello.dat file selected.
Ajay_MV
on
Is there any way to select multiple files?
Ajay MV
