Overview
This vi will display a folder path in windows explorer by using system executive.
Description
This vi will programmatically use System Executive to display a folder in Windows Explorer. It uses the file path selected by user and converts to a string which is passed to system exec.vi with the command "explorer <folder path>"
Requirements
VI Snippet
Thanks Hex. Slight mis-hap when cleaning up this vi for the community! - Have updated
Hehe, no problem. I just got real lucky ![]()
Works in Vista. Thanks very much for your vi.
Another nice option here is the ability to select a file in the opened folder. This can be achieved by adjusting the command with the select switch:
explorer /select,c:\test\hello.dat' will for example open an explorer window showing c:\test, with the hello.dat file selected.
