This example shows you how to programmatically create an enumeration variable using the TestStand API.
Description-Separate-2
1. You should create a property object with value type Container using the NewPropertyObject Method:
If you are interested in creating a data type refer to Using the TestStand API to create a Data Type.
Additional-Separate-2
Related-Separate-2
Clear and detailed explanation on creating an enumerated data type. Nice work!
For anyone interested, I have posted a version of this example using TestStand Expressions here:
