Example Code
Programmatically Create Enumeration Variable in TestStand
Products and Environment
    Software
  • LabVIEW
  • Teststand
Code and Documents
Description
This example shows you how to programmatically create an enumeration variable using the TestStand API.
How to Use
1. You should create a property object with value type Container using the NewPropertyObject Method:
2. Then define a name for the property object and the number of elements it will contain using the Name Property and SetNumElements Method:
3. After, you can populate the property object, each element in the container should have two sub properties: EnumeratorName and EnumeratorValue that you can add using the NewSubPropery and SetValString and SetValNumber respectively methods:
4. You should create also a new data type using the NewDatatType method and name it using Name Property:4rtaImage.png
5. By default, the data type is empty, to populate it you can use the Update enumerators method passing the reference of the created container:
6. Finally, you can insert the enum data type in the type usage list of the current sequence file using the InsertType method, use the IncChange Count method required to indicate to the sequence editor or user interface that the file was modified and the SaveFileIfModified method to save the changes in the sequence file.
7. To create a instance of the enum data type you can use the NewSubProperty method, for example to create a local variable:
Note: The LabVIEW (2019) code described in this document is provided as attachment.
Additional Information
​​​​​​If you are interested in creating a data type refer to Using the TestStand API to create a Data Type.
Related Links
Comments
GeekGrok
on
Clear and detailed explanation on creating an enumerated data type. Nice work!
vrv
on
Nice. Is it possible to update the Enum type without delete and create again?
Mr._Jim
Active Participant Active Participant
on
For anyone interested, I have posted a version of this example using TestStand Expressions here:
https://forums.ni.com/t5/NI-TestStand/How-to-create-new-enum-data-types-with-teststand-API-Is-anyone...
