Example Code
Open a PDF File using command line using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example shows how to open a PDF file using System Exec.vi.
Description
This example creates a command line that open a PDF file and passes it to System Exec.vi.
Requirements
  • LabVIEW 2012 (or compatible)
  • PDF reader
  1. Select a PDF file
  2. Run the VI
VI Block Diagram
Comments
toto69
on
You are not using ActiveX here.
You only launch the command line and type the path to the pdf file.
Have a look here for a real use of ActiveX : https://decibel.ni.com/content/docs/DOC-2163
CFiset
on
It's not ActiveX!
Sujo
on
This is not using ActiveX
CFiset
on
Just retouch the text (replace ActiveX for System exec.VI). Hope I don't make any error
carlos_camargo
on
This is great!  It works for me.
MiloB
on
thank you, it works
beuvink
on
the /c did the job. Thanks!
25+ years long fan of LabVIEW. Move to Emerson looks to be for the better! See the last posts in subscription model thread.
