Example Code
Get System Cursor Info (win API and .NET) Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example VI shows how to how to obtain current cursor position, hotspot and cursor's bitmap data.
Description
You can use the VI to get specific information of the cursor such as position, hotspot and cursor's bitmap data by calling Libraries & Executables VIs and Functions
Requirements
  • LabVIEW 2012 (or compatible)
  • Libraries & Executables VIs and Functions 2012 (or compatible)
1.Place the cursor.
2.Run the VI.
VI Snippet
Comments
Hooovahh
Proven Zealot Proven Zealot
Proven Zealot
on
I had a few issues using this code.  It mostly worked but some times would return an exception from the DLL call, but the pointer and other information was valid, so I cleared the error if it looked normal.  I also see you are getting the mouse position twice, once in the DLL, once in .NET, I saw they were always the same so removed the .NET call.
And I'm not sure if it is more efficient, but I found getting the image by saving it to a PNG buffer, then using a vi.lib function to turn that into a LabVIEW image, to be simplier.  These changes were posted in this thread, where I was trying to get the cursor image but ended up using a different solution.
AntMeTech
on
I have a problem with this VI. In Win10 and LabVIEW 2019 it does not work. Any suggestions? Thanks in advance
wiebe@CARYA
Knight of NI Knight of NI
Knight of NI
on
