Example Code
Differential M-PSK Demodulator
Products and Environment
    Software
  • LabVIEW FPGA Module
Code and Documents
Description
Overview
This example demodulates a continuous differential M-PSK modulated signal.
Description
This example demodulates a continuous differential M-PSK modulated signal, and tracks timing and frequency offset. In addition, if the transmitted bit sequence is a Galois PN sequence, then bit error rate can be measured.
  1. Unzip and open the project.
  2. Deploy the FPGA bitfile to your PXIe-5641R.
  3. Open host VI and customize Rx configuration.
  4. Run host VI.
Requirements
Software
LabVIEW FPGA 2010
LabVIEW FPGA RF Communications Library 3.0 available on NI Labs
Hardware
PXIe-5641R
Comments
WayneSun
on
This is a very good example to understanding the DBPSK algorithm.
kkhaleel786
on
there is no zip file in this ......
plese help me any one where i can find it example code for dbpsk
ChenYong
on
I am using PXIe-5641R to make a DPSK modulator. Is there am example to do this?
Vinay_Kumar
on
jadoon
on
Hello every one,
             i am using this example  LV2010 5641R DPSK demodulator .when i compile this on NI PXie 5641R i get the following error shown above.it keeps on compiling for about 38 minutes mentioning generating cores.then this error appears.so any one knowing about this error.
My system RAM is 4 GB .
thankyou.
Chris-NI
NI Employee (retired)
on
Hi jadoon,
Please try applying this hotfix - http://joule.ni.com/nidu/cds/view/p/id/3864 .  If that doesn't work, I would advise you to call support  at (866) ASK-MYNI or post in our forums .  Our systems don't streamline the ability to support you through the comments section of these documents.
Good luck!
Chris Elliott
x36772
jadoon
on
Hi chris,
                 thankyou for reply. i am using Labview 2011 SP1.the patch you mention is for 2012 SP1 .so any solution possible for that..
thankyou .
aral8051
on
please convert
LV2010 5641R DPSK Demodulator.zip
to labview 2009 with me
thancks my dear
