Overview
This example demodulates a continuous differential M-PSK modulated signal.
Description
This example demodulates a continuous differential M-PSK modulated signal, and tracks timing and frequency offset. In addition, if the transmitted bit sequence is a Galois PN sequence, then bit error rate can be measured.
Requirements
Software
LabVIEW FPGA 2010
LabVIEW FPGA RF Communications Library 3.0 available on NI Labs
Hardware
PXIe-5641R
Description-Separate-2Example code from the Example Code Exchange in the NI Community is licensed with the MIT license.
there is no zip file in this ......
plese help me any one where i can find it example code for dbpsk
I am using PXIe-5641R to make a DPSK modulator. Is there am example to do this?
Hello every one,
i am using this example LV2010 5641R DPSK demodulator .when i compile this on NI PXie 5641R i get the following error shown above.it keeps on compiling for about 38 minutes mentioning generating cores.then this error appears.so any one knowing about this error.
My system RAM is 4 GB .
thankyou.
Hi jadoon,
Please try applying this hotfix - http://joule.ni.com/nidu/cds/view/p/id/3864. If that doesn't work, I would advise you to call support at (866) ASK-MYNI or post in our forums. Our systems don't streamline the ability to support you through the comments section of these documents.
Good luck!
Hi chris,
thankyou for reply. i am using Labview 2011 SP1.the patch you mention is for 2012 SP1 .so any solution possible for that..
thankyou .
