Discussions au sujet des autres produits NI
annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
labview daqmx
hello,
i use labview 8.6 with the daqmx assitant to adquire differents signals, but all in analogic...
i can display the value of the voltage linking the data of "daqmx assistant" at a waveform graph and a numeric indicator similar with a txtbox, but which accept a type of "double"...
in the program i have to do, i want to display this voltage, differents currents and powers in differents numeric indicators..
i know i have to adquire these currents by creating anothers channels in the same task, but i don't understand how i can display these currents in others numeric indicators, i can link the data of "daqmx assistant", but how can i do to separate and get the current and the voltage, i can see the boths in the waveforme graph...
somebody can help me ,????!!
Thx
0 Compliments
Message 1 sur 2
3 340 Visites
Hi Thias061,
Thanks for posting on the National Instruments Forum.
This part of the forum is in French, if you want to post in English you can go here.
Well, you have a function which split your signal to be able to display them into different indicators.
Message Edité par BenjaminR le 03-20-2009 07:34 AM
    Benjamin R.
Senior LabVIEW Developer @Neosoft
0 Compliments
Message 2 sur 2
3 319 Visites
