le 03-17-2009 10:31 AM
I want to make a Front Panel DataSocket Connection in my VI, but unfortunatily when I right click a control or an indicator, I can see Data Operations
as explained in the DataSocket Tutorial Document http://zone.ni.com/devzone/cda/tut/p/id/3224 but not DataSocket connection.
Please tell me what should I do ,
le 03-18-2009 10:16 AM
The following post deals with the problem you are experiencing :
http://forums.ni.com/ni/board/message?board.id=170&message.id=290734&requireLogin=False
It appears effectively that the tutorial is obsolete for the LabVIEW version you may have, and therefore the contextual menu "DataSocket Connection" is not there any more.
You have to go through the properties of the control and select the data binding tab.
Hope this help
have a nice day
Rémi M.
National Instruments France
>> Les présentations NIDays 2010 déjà disponibles au téléchargement !
le 03-20-2009 05:32 AM
Thank you Rémi,
so there is no diffrence between "front panel data binding" and "Datasocket Connection,
it depends on which LabVIEW version I am using.
Best Regards,
rose2009
