cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Error #3 memory.cpp line 563
I have a problem with Labview 6.1 and the historics trends. I've got the following configuration:
1.- Labview 6.1 and DSC 6.1
2.- Windows XP
3.- Historical Database Labview - Citadel.
4.- For saving historical Database, i use de "Write Analog Tag.vi" function.
5.- For representing the Historical Trends, I use the "Read Historical Trend.vi" function.
6.- While representing Historical Trends, suddenly the programs stops into the "Read Historical Trend.vi" function. If you try to stop the program, labview crash and it's necessary to close it from the windows main manager. However, Tag Engine follows running without any problem. Sometimes instead of this, "Error #3 memory.cpp line 563" mesagge appears and it's neccesary to close windows.
Anyone can help me?
0 kudos
Mensaje 1 de 3
5.833 Vistas
Hi Nkcube!
I'm wondering if you are using a "Delete from array.vi" in your main code, if that's the case the following link can help you solve your problem.
http://digital.ni.com/public.nsf/allkb/EC243E8B7E376D7086256F51006F2484
If that's not the case i recommend you read the following:
http://digital.ni.com/public.nsf/allkb/AB16C6E8782FEB9E86256B3E0059A26F
I hope this helps you solve your issue 🙂
Oswald Branford
0 kudos
Mensaje 2 de 3
5.831 Vistas
Hi Oswald,
Thanks a lot for you quick answer.
Unfortunatelly, my problem is not resolved with your two recomentations, due to no one of them appears in my program.
In fact, the problem only happens while using the "Read Historical Trend.vi" function.
I dont call dll, cause my program only calls Labview functions. Its supposed that inside that functions are lots of dll's, but i cant find out then cause are password protected.
How I'd said, progams runs ok sometimes during 5 minutes or in other chances during 5 hours, but in both cases labwiew crash at the end.
I've noticed that with WINDOWS 2000 OS, the programs runs during more time, but also crash.
Maybe labwiew 6.1 does not runs fully with WINDOWS XP for being older???
Thanks.
0 kudos
Mensaje 3 de 3
5.815 Vistas
