Digital Multimeters (DMMs) and Precision DC Sources
Time base and sampling rate with Tektronix DMM 4040 and 4020
I'm using the Tektronix DMM4040 with LabView Signal Express Tektronix Edition. When logging time-dependent data from the DMM4040, the results are displayed as a function of the number of 'iterations'. How can I correlate the number of iterations with the time (e.g. since the beginning of the log) ? When a duration in seconds is defined as a stop condition for the log, the logging terminates at the number of iterations, not the number of seconds. If, for instance, a duration of 30 s is specified and the sampling rate is approximately 2 iterations per second, execution terminates after 15 s, not 30. This is clearly a malfunction of the software.
I would like to able to record my data as a function of time directly, ideally without having to manually convert iterations to seconds. As far as I can see, there is no way how the software could tell me how many iterations correspond to a second.
I hope someone can help ...
With many thanks in advance !
(6,348 Views)
This board is for NI DMM's and DC sources. You should post your question to the SignalExpress board.
(6,345 Views)
Sorry, I didn't know such a board existed.
Thanks for pointing it out.
(6,336 Views)
