‎10-15-2013 03:45 AM
I'm using the Tektronix DMM4040 with LabView Signal Express Tektronix Edition. When logging time-dependent data from the DMM4040, the results are displayed as a function of the number of 'iterations'. How can I correlate the number of iterations with the time (e.g. since the beginning of the log) ? When a duration in seconds is defined as a stop condition for the log, the logging terminates at the number of iterations, not the number of seconds. If, for instance, a duration of 30 s is specified and the sampling rate is approximately 2 iterations per second, execution terminates after 15 s, not 30. This is clearly a malfunction of the software.
I would like to able to record my data as a function of time directly, ideally without having to manually convert iterations to seconds. As far as I can see, there is no way how the software could tell me how many iterations correspond to a second.
I hope someone can help ...
With many thanks in advance !
‎10-15-2013 01:06 PM
This board is for NI DMM's and DC sources. You should post your question to the SignalExpress board.
‎10-16-2013 01:31 AM
Sorry, I didn't know such a board existed.
Thanks for pointing it out.
