Digital Multimeters (DMMs) and Precision DC Sources
Error code:-50251 while performing selft test
I had received the mentioned error while performing self test for PXI-4071 eventhough drivers are installed .
Staus code:-50251
NI Platform Services: The specified software component is not available
AB
Kudos are Accepted
(6,222 Views)
* Is this from MAX? Or through the API? * What version of NI-DMM do you have installed? * Do other things work? SFP? Examples?
Marcos Kirsch
Chief Software Engineer
NI Driver Software
(6,181 Views)
Marcos Kirsch
NI Driver Software
(6,179 Views)
Accepted by topic author AB@17
This is in MAX while performing self test, The issue was with drivers mostly.
After formatting the PXI controller. Issue resolved
AB
Kudos are Accepted
(6,099 Views)
Reinstalling drivers has not worked
AB
Kudos are Accepted
(6,084 Views)
