‎02-12-2017 11:12 PM
I had received the mentioned error while performing self test for PXI-4071 eventhough drivers are installed .
Staus code:-50251
NI Platform Services: The specified software component is not available
‎02-14-2017 02:18 PM
‎02-14-2017 02:19 PM
Is this from MAX? Or through the API?
What version of NI-DMM do you have installed?
Do other things work? SFP? Examples?
‎03-10-2017 06:47 AM
This is in MAX while performing self test, The issue was with drivers mostly.
After formatting the PXI controller. Issue resolved
‎03-12-2017 11:34 PM
Reinstalling drivers has not worked
