Digital I/O
scb-68 and PCI-8331 what is converting my analog sgnal into digital%3F
Long ago, around 7 years ago, I worked on a project in which I interface photodetector to my computer through SCB-68 kit. The SCB-68 kit was connected to computer using PCI-8331 card.
Now, my input was analog signal from photodetector but at programming interface I was getting digital values for computation. Now my confusion about the conversion task done by which part of this connection?
SCB-68 was converting the input signal and supplying digital output? or PCI-8331 was doing digitization before delivering information to computer? or labview itself was doing it after getting signal from PCI-8331?
can anyone please clear me?
Thanks!
(5,094 Views)
The scb-68 is just a dumb terminal block. The pci-8331 is http://sine.ni.com/nips/cds/view/p/lang/en/nid/13179  and does not connect to photodetectors so your memory is flawed about the part number. An actual DAQ card would have done the conversion.
(5,086 Views)
Thanks for your response.
Yes.. you are right..  PCI 8331 is not capable of receiving signal from photodetector. I must have used chesis inbetween.. SO you mean there was a DAQ card whch was communicating between SCB and PCI and was doing the digitization?
Thanks!
(5,082 Views)
Accepted by sukhiray
Of course there was a DAQ card someplace.
(5,080 Views)
