Digital I/O
Using the NI USB-8452 from a 64-bit C++ Application
Is there a 64-bit version of Ni845x.lib and Ni845x.dll that can be used from a 64-bit C++ application.  Previous responses suggested that only a 32-bit version was available, but our application is 64-bit only.  I would prefer not to have to create a framework to thunk down to 32-bit in order to use the current version (19.0) of the DLL.
(2,706 Views)
I had the same exact question as I have the need to develop an x64 application with the ni845x.lib.
Did you ever get an answer from someone if an x64 version of the library exists?
(1,887 Views)
Hello, do you have any news about the topic?
I´m in the same situation.
Best regards
(503 Views)
If you installed the right components, you will find the 64-bit dll as described below,
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019La7SAE&l=en-US
Santhosh
Soliton Technologies
(499 Views)
