Digital I/O
Using the NI USB-8452 from a 64-bit C++ Application
Is there a 64-bit version of Ni845x.lib and Ni845x.dll that can be used from a 64-bit C++ application.  Previous responses suggested that only a 32-bit version was available, but our application is 64-bit only.  I would prefer not to have to create a framework to thunk down to 32-bit in order to use the current version (19.0) of the DLL.
(1,991 Views)
I had the same exact question as I have the need to develop an x64 application with the ni845x.lib.
Did you ever get an answer from someone if an x64 version of the library exists?
(1,172 Views)
