Digital I/O
Time out error when trying to calibrate a PXI-6552 using Calibration Executive.
I'm getting an error I've never seen before when trying to calibrate a PXI-6552 using Calibration Executive. We have been calibrating these cards for 3 years and never had a problem. The error I am getting has to do with the HP 3458A DMM taking a reading.
Error -1074126845 occurred at IviDMM Read.vi at step Verify Generation Voltage
Possible reasons: Driver Status (Hex 0xBFFA2003)Max time exceeded before operation completed.
Primary Error: (Hex 0xBFFF0015)Timeout expired before operation completed.
As soon as Cal Exec sets up the PXI-6552 then goes to take a reading from the 3458A an SRQ message appears on the 3458A, then the above error message pops up in Cal Exec. I've tried re-installing the NI-DMM drivers. The voltage on the DMM display is good for the first step (5.5 volts DC) but it times out and gives me the error as stated.
(3,835 Views)
Accepted by topic author Rick Gill
Nevermind, I got latest drivers and installed them and everything is working fine now.
(3,826 Views)
