Digital I/O
POSSIBILITY DATA TRANSFER BETWEEN PCs VIA ETHERNET PORTS USING LABview??
I am working on transferring data from pc to pc via ethernet ports. Is it possible to do this using ANY technique in LABview or any of its features??
I need your help urgently. I am a little short of time. Any help would be highly appreciated.
regards,
Danish
(4,417 Views)
Please don't shout and why would you post to this board? Your question has nothing to do with digital I/O.
In any case, of course you can do this. Have you even looked at the examples that come with LabVIEW? There is TCP/IP, UDP, Network Streams, etc. All under the Networking topic in the Example Finder.
(4,415 Views)
Hi Dennis,
Thank you for replying. No sir i wasn't shouting!! I apologize  if my writing sounds that way!Smiley Sad
So which board do you recommend i post this question related to this?.. And can i have a little more help from your side as to how to go about it?
Danish
(4,411 Views)
All caps (as in your subject) is considered shouting.
It's a LabVIEW question. Did you run any of the examples? Did you have any specific question about one of them?
(4,406 Views)
Hey Danish,
TCP/IP is definitely possible using LabVIEW.  There are a lot of great examples that come with LabVIEW. You can find them by going to Help->Find Examples. From the contents menu there you can look under Networking->TCP and UDP to try out those examples.  Additionally there are some Developer Zone articles available online: http://zone.ni.com/devzone/cda/tut/p/id/2710
Let us know if you have a specific problem with one of these examples or your TCP/IP code.
Kevin Fort
Principal Software Engineer
NI
(4,374 Views)
