Digital I/O
USB 6509 - Digital Pattern Generation
I have USB - 6509 which is only DIO, and I want to generate digital pattern, "10110001110010" something like that.
Could you help me how I can generate?
Message 1 of 9
(6,124 Views)
Is that for a single pin or multiple? what language?
Message 2 of 9
(6,115 Views)
Initially, I want to do single pin, and I am using Labview English version.
Message 3 of 9
(6,112 Views)
You could simply have a DAQmx Write (Digital Boolean 1Line 1Point) inside a for loop with an array of Booleans outside. Wire through to the Data input.
Message 4 of 9
(6,106 Views)
Thanks for help.
I am a real beginner for using Labview, and could you give me the block diagram. I am using labview 2009.
I know how to generate DAQ assistant input and output.
So line 0 for port 0 physically wired  to line 0 for port 3. So I want to check the input patterns.
To check the input patterns can I see by waveform or table?
How can I array inputs - 1011011011 or 1010101010?
Message 5 of 9
(6,096 Views)
Simple as this. You can use either a Boolean or numeric array.
Message 6 of 9
(6,094 Views)
how do you generate that input array?
Programming- boolen-true and false constant?
Message 7 of 9
(6,080 Views)
Drop an array constant and place a numeric constant or a boolean constant inside the array void (blank space in the right pane).
Applications Engineering Specialist - Semiconductor Test
Message 8 of 9
(6,071 Views)
Yes,
I would suggest taking the basic LabVIEW tutorial.
Message 9 of 9
(6,070 Views)
