Digital I/O
Can I do continuous digital input and/or output with my PCIe-6259?
I don't have my R series yet so I can't test it, but this should work, at least in a form very similar to this.
Angle detection:
http://www.280z28.org/images/z/ecu/engine_speed_angle_detect_1.png
Handling updates to angle changes:
http://www.280z28.org/images/z/ecu/fuel_spark_1.png
Side note: 30" Dell = Smiley Very Happy
Edit 2: (and the compilation is sloowwwwwwww my gosh they weren't kidding!!). Looks like I'm going to have plenty of room although I wouldn't have enough room with the 1M ones.
Compilation Summary
Device Utilization Summary:
   Number of BUFGMUXs                  2 out of 16     12%
   Number of External IOBs           214 out of 484    44%
      Number of LOCed IOBs           214 out of 214   100%
   Number of MULT18X18s               20 out of 96     20%
   Number of RAMB16s                  10 out of 96     10%
   Number of SLICEs                 4943 out of 14336  34%
Message Edited by 280Z28 on 08-17-2006 07:43 AM
Message 21 of 23
(1,763 Views)
Interesting app...   I'm not sure I've got a handle on all the details, but with what time I've got, hopefully the following comments are useful.
1. For the record, it IS possible to perform hardware-timed "correlated" digital input and output simultaneously.  I've had an app going for months that generates an 8 bit buffered output pattern on the leading edge of a sample clock and acquires a 24 bit response digital pattern on the trailing edge of the same clock.  I'm using a 6259 as well.  I'm also using all the static DIO bits for various other inputs and outputs without interrupting the continuous buffered acquisition.
2. If you perform an "on-demand" period measurement, you may stall out your loop waiting for the DAQmx call to return with a new measurement.  Another possible option is to perform continuous period measurement.  Then you can use a DAQmx Read property node to specify that you'd like to request the most recent data that's already in the buffer.  No waiting.  (The properties needed are "RelativeTo" = MostRecentSample, "Offset" = -1.)
3. This helps one aspect of your skew problem but another remains.  The delay from when you write new DO values into the DO buffer until the time when they actually show up as output signals.   Here you can help yourself somewhat by using another DAQmx property node with a name similar to "Data Transfer Condition".  Basically, this property controls how much the boards hardware FIFO gets ahead of the system RAM buffer you write to.  There's a non-default setting that'll give you faster response at the expense of more frequent short bursts of bus traffic, and hence more risk of underflow errors.
4. I've done this stuff using LabVIEW so I've got no help for C-family syntax for driver calls.
5. The higher the resolution of the encoder you use for period (speed?) measurement, the better you can expect the resulting value to approximate the instantaneous speed.
6. The problem of skew during speed changes is fundamental to the control system.  You've got a time delay in your feedback signal.  You've also got a time delay in your output control signal.  In such a case, you cannot maintain 0 following error (0 skew) during a ramping input.  Not unless you can invent what one of my profs used to call a "swami" controller, that exactly anticipates the future feedback signal so you can generate the control output.  (There's actually some theory for how you might try to do this for systems with fully known inputs, but I'm assuming that you're dealing with a non-academic real-world case with random-like disturbances.)
-Kevin P.
Message 22 of 23
(1,713 Views)
Hi Kevin,
Thanks for your additional information.  You are absolutely right that you can perform both correlated digital input and output simultaneously.  I had never tried this, but I just tested it and it worked beautifully.
Thanks again for your insight!
Message 23 of 23
(1,684 Views)
