I sometimes need to launch and stop a tester programmatically (mainly from TS).
I can launch the tester programmatically using VI server, but I need to do this wrapper for each tester.
To stop a tester, there is no way to actually do it programmatically.
The only action that stop a tester is manual one (closing the tester's window).
I would like a Tester API (basically 2 VIs) created by default in every module that would allow me to launch and stop a tester programmatically.
Hi @CyGa,
We understand your use case. Unfortunately, we are not keen to create, maintain, and document an API for the API Tester.
That said, thank you for your input. It is most appreciated.
Please keep those ideas coming!
